tanvir390
Hi . I am Tanvir. I have one damaged 450W computer power supply. I have checked all the components like MOSFETs, Transformers ,inductors,transistor, IC (ATE2005) And other components. I have found that one power BJT( MJE 13007) has damaged, and I have replaced it. After the repair I have checked the voltage output , the output was normal as before the damage. I have used 12 V cooling fan to be drive by it and it runs smoothly. But when I used it to my pc, It damaged again. I think that that It unable to supply the required power to the pc and damaged. But when I checked again, I have found that same transistor has damaged and other all the components are good except the filter capacitor for filtering the ac supply I have not checked. I do not how to check them accurately. I have checked them with the multimeter and I found as them seems to be OK. So what is the problem ? why the power supply did not able to supply the PC even if I have repaired the damaged component? Is there any problem with the large electrolytic capacitors? or there is any other problem?
Please help me in this respect with step by step instructions. Thanks
