How to rename a file in VB.NET
metal
Full Member level 6
Full Member level 6
vb.net rename file
Hi
I was writing a small peice of code in order to be able to change the file name from within my software. Any one has idea of how I can do that.
Thanks in advance :)
from VB6 i remember a command called Name, im not sure as to whether it will work in VB.NET but its worth a try
Hi
My friend, there is no RENAME method in VB.NET, thats why I was asking on how to make it.....
man be more specific what file name are you on about ? your applications exe etc... wtf name do you mean
ps happy new year...!!!
Hi
I need to specify a file from the open dialog, then I get its name, after that I want to process the file name, for example, use ToUpper method to make all letters capital, after that rename the same file with the new processed string.
Thanks
Hi
I just need to know how rename a file in VB.NET,thats all. For a practiced programmer, its too easy to answer.
Thanks
VB.NET source code showing how to move or rename a file.
' How to move / rename a file.
Private Sub button6_Click(sender As Object, e As System.EventArgs)
Dim fi As New FileInfo("myImage.gif")
fi.MoveTo("myImage2.gif")
End Sub 'button6_Click
Hi
Thanks alot. I have already solved that problem.
