How to remove unwanted warnings on the Altium messages window?
venn_ng
Member level 5
Member level 5
Is there a way on Altium to ignore the Schematic compilation warnings that you feel can be waived off on the messages window like the ones shown below? I made it the port intentionally to be unspecified because I wanted VIN to be a power net and it was throwing some errors/violations if I connected the input port to a power net.
I have included the design below. I have indicated which one is the unspecified port and which one is the power net.
Thanks in advance.
UPDATE: I think I figured it out. You have to modify the check boxes on the Project Options Dialog box, right?
UPDATE 2: After disabling "Net with only one pin" error on the Project Options window, apparently all other warnings that I faced also stopped appearing when I complied and the message window is clean
