How to remove Initial delay in IBIS VT Curve
skynet
Member level 5
Member level 5
removing initial delay
Hi guys,
Do anyone here know how to remove Initial delay in ibis VT curve?
thanks
SkyNet
SkyNet,
Why do you want to remove the initial delay?
Be careful -- V-t tables should be time-correlated across the same corner. Removing the delay from one waveform but not the others could cause mismatches versus the original design.
- MM
