AA.C.3 Sized AA density also inside NODUMMY region, should be min 0.20, for Window of 100*100 microns (AA.C.3)
: Except where spacing is smaller than 8 Microns.
AA.C.5 AA.C.3 Sized AA density also inside NODUMMY region, should be min 0.20, for Window of 100*100 microns (AA.C.5)
: Except where spacing is smaller than 20 Microns.
Add "dummy" transistors in the "white spaces" between
active "real device" regions. These are fine-grained density
rules checks.
You could also, and maybe more so, benefit from putting
ptap unit cells everywhere they will fit, whether or not you
connect them to ground / sub! by wiring - they're a LVS
"freebie" requiring no schematic dummies to match, or
pruning rules.
rules checks.
pruning rules.
