How to reduce the photodiode detect noise?
xuruquan
Junior Member level 3
I use photodiode to detect the fiber sensors,but the noise is big ,so i can't detect the peek of the pulse ,who knows how to reduce the photodiode detect noise??
thank you!
Re: photodiode!
thank you!
Normally the noise like fliker noise operate at low frequency, try implement the bandpass filter to eliminate unwanted noise.
Re: photodiode!
The photodiode usually comes in a package that allows good fitting and alignment of fibre to diode. Your experience is rather unusual.
You can use a waveguide filter, if you know the band of the light frequencies to pass.
Another possible reason is perhaps due to the mode used and dispersion in the fibre.
Re: photodiode!
Is the noise present when the diode is covered over with black material? Does the noise rise when a signal is present? This last item is called RIN or relative intensity noise. Use another type of detector diode if this is the case.
