The graph below shows the post simulation using the R+C+CC and C+CC extractions.
The problem can be traceable to the parasitic resistance.
The expected result is the same as that of the C+CC.
My concern now is how to reduce the parasitic resistance in the layout.
I have no idea on specifics of LED and associated Layout.
In general :
1. Widen the wires if possible [not violating DRC of course].
2. In case there are multiple metal layers - between layers in case you have VIA - increase the number of Via-counts in parallel, that will reduce parasitic resistance.
