d123
Advanced Member level 5
Further to the clamp circuit I asked about, I simulated it and breadboarded it today and it works as well as may be hoped/expected. I wish LEDs were more like capacitors than diodes regarding gradual turn on rather than having a Vf, anyway.
From what I'm reading and simulation and breadboard results, op amp clamps never go down to 0V, even with 0V input?
If so, is there a way of making 0V in mean 0V out? Pull-down resistors in various obvious places made no difference.
On turning the circuit on with the switch, the LEDs dimly glow before pressing the 'ON' button, and the 'OFF' button never fully turns them off, even though the charge capacitor voltage reads 5mV.
Don't mind need for switch but would be nicer with only the two pushbuttons.
Quiescent current is 2mA, housekeeping over 3mA, this is also undesirable. Is that likely to just be the components I'm using in this version?
Again, sorry for drawn schematic, can't turn on laptop to do neat schematic right now. Pictures are schematic of actual circuit and same circuit on breadboard.
Thanks.
Hi again,
Two corrections:
1) Charge capacitor is 10uF, not 22uF.
2) I am an idiot. Quiescent current is only ~850uA. I forget to remove the green LED (top right on breadboard) when measuring total supply current...
Thanks.
--- Updated ---
Hi again,
Two corrections:
