uday mehta
I am doing some test experiment using high gain amplifier as I have very low input.
but on general pcb or on bread board I am getting unwanted signal may be due to coupling. when I am applying 3 V AC from my signal generator I am getting 200 mv at oscilloscope when generator and oscilloscope probe are 2 or 3 mm apart in air ( means without any connection). I think both probes are acting as an antenna.
how to reduce this antenna effect as I have to connect generator pin 1 mm apart from amplifier input pin. due to this effect I am getting nearly 1 v AC at output of amplifier even with out any connection of ip of amplifier and generator pin.
