chitra ranganath
Member level 2
![Member level 2](/styles/images/ranks/dlevel2.gif)
hi can pls somebody help me in solving this doubt
z= 10101010 1 1 0 10101111 0 11111111
here in this i`ve stored some bits with spaces in reg z
the logic is after reading 1st 8 bits i`ll see wat is next bit.
if it is '1' i should get output as previous same 8 bits.
else if bit is '0' i shd get next 8 bits.
so output for this sequence above must be
out= 10101010
10101010
10101010
10101111
11111111
pls help me out
for j=1:1:8
res(j)=zb(j);
end
disp (res);
for i=9:1:nbits
if(zb(i)==' ')
res='\n'
end
if(zb(i+2)=='1')
res(i)=zb(i-12);
elseif(zb(i+9)=='0')
res(i)=zb(i+12);
end
end
out= 10101010
10101010
10101010
10101111
11111111
pls help me out
for j=1:1:8
res(j)=zb(j);
end
disp (res);
for i=9:1:nbits
if(zb(i)==' ')
res='\n'
end
if(zb(i+2)=='1')
res(i)=zb(i-12);
res(i)=zb(i+12);
end
end
