[SOLVED] How to record voice in WINBOND IC?
agg_mayur
Member level 3
Member level 3
India
Dear All,
Please tell me , how to record the voice in windbond's voice recorder IC with using microcontroller?
Is there any seperate circuitry for the same and how to interface it with microcontroller?
oh! is it so?
Actually i want to make a circuit in which i can record the voice of approx 60-120 secs. through audio in from PC and take output from that IC with speaker(with external amplifier.)
In my cicircuit i'll give the provision that when any task done i'll play that audio by simply giving vcc or gnd(high or low like buzzer) to the audio circuit.
You can use APR9600 in that case... it suits your application.. Please download the data sheet of it... I am sure thats the solution you are looking for..
I had used it for some announciation system long back... it is still available
Thanks for the solution... I found the datasheet, yet not checked but after seeing its datasheet i hope it will work.
