ezyneab
dsk6713_aic23
original
I can talk is 24000/8000 = 3sec original i don't need
original
//Record.c Illustrates use of external memory with voice as input
#include "dsk6713_aic23.h" //codec-DSK support file
Uint32 fs=DSK6713_AIC23_FREQ_8KHZ; //set sampling rate
#define N 24000 //large buffer size
long i; short var; //flag when recording/playing
int buffer[N];
#pragma DATA_SECTION(buffer,".EXTRAM") //buffer->external memory
void main()
comm_poll(); //init DSK, codec, McBSP
DSK6713_DIP_init();
DSK6713_LED_init();
while(1) //infinite loop
if(DSK6713_DIP_get(3) == 0) //if SW#3 is pressed
DSK6713_LED_on(3); //turn on LED#3
for (i = 0; i<N; i++)
buffer = input_sample(); //input data
DSK6713_LED_off(3); //LED#3 off when buffer full
break;
var = 0;
while(1)
if((DSK6713_DIP_get(0)==0)&&(var==0)) //if SW#0 pressed/var=0
DSK6713_LED_on(0); //turn on LED#0
output_sample(buffer*10); //play back
var=1;
DSK6713_LED_off(0); //LED#0 off when finished
if(DSK6713_DIP_get(0)==1) var=0; //toggle flag
I want to record voice dynamic mem by mean don't define time for record
but time for record be under the control of dip switch when on and off mean
start record when on switch and stop record when i release switch
I use dsk c6713.
thank you
original
original
int buffer[N];
void main()
DSK6713_DIP_init();
DSK6713_LED_init();
break;
var = 0;
while(1)
var=1;
I use dsk c6713.
thank you
