How to reconstruct MMW image using electrical field in each direction at Reciever points
mohamis288
Full Member level 3
Full Member level 3
I have used a structure including 109 Receivers and 4 transmitters in order to do MMW imaging(multistatic imaging). Imaging was done in 3 different frequencies. So, now I have electrical field in each direction at each receiver point resulted from each transmitter at those frequencies. I just want to know how can I implement it in matlab or python.
Can you give me a step-by-step guideline, sample code or document for implementation?
Actually, this is the best article I found in this subject, But i can not understand its implementation perfectly:
"Walk-through millimeter wave imaging testbed
based on double multistatic cross arrays"
**UPDATE**
Here is the link to the available data:
nearfield data
actually I found some manuals especially the one available in this link. But some concepts in this link (like "rotation") are not mentioned in the previous article. also, some concepts like "wavenumber" and "the number of transmitters" are not discussed in this link. I am a little confused.
