carpenter
Full Member level 6
I ordered a 20W UV LED 365-370nm from China.
The diode arrived today
The LED is 20W, i.e. it contains two rows of 10 diodes each
In the picture, approx. 200mA flows through it at a voltage of 32V 30% from 20W .
Photographed in the dark-
The LED shines quite intensely white, as you can see on the banknote in front of the LED, there is some UV there, see the blue glowing fibers
The intensity of the white surprised me. is it normal or did the Chinese intentionally or unintentionally make a mistake and send another definitely noticeably cheaper LED?
I want UV LED to expose Photopolymer Dry Film, for which the manufacturer recommends ´350-380nm UV Light-
Manufacturer recommends Exposure energy 50 mJ/cm2). There is no datasheet for LEDs from China, does anyone have an idea of what energy is actually emitted from a 365-370nm LED at 20W so that it can be calculated Exposure energy i.e. exposure time
