u can implement it with transmission gates also
there u only need 6 transistors to make an xor gate
or u can take 4 transistors and implement an xor gate
Can I ask, I was about to start a new topic but I will post here now. How do I realize an XOR gate using ordinary (one way) switches? For instance AND gate is realized by two one way switches in series. Only if both are closes (ON) the output is high. What would be the circuit for XOR?
