How to read temperature from pic16f628 and css c compiler
KiuFelix
Newbie level 5
I am trying to read temperature values from a LM35. This is how my code is arranged
// Function:  Temperature logger: UART at 9600 baud
// Processor: PIC16F628 at 4 MHz using internal RC oscillator
// Hardware:  K4
// Software:  CCS PCM
// Author:	  Cheruiyot Felix, felix@nairobicoder.com
// Credit:    Lars Petersen, oz1bxm@pobox.com
#include <16F628.h>
#fuses INTRC_IO, NOLVP, NOWDT, PUT, BROWNOUT
#device ADC=8;
#use delay(clock=4000000)
#use rs232(baud=9600, xmit=pin_B2, rcv=pin_B1)
void main() {
//Initialize values
unsigned int val;
int t;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_INTERNAL);
set_adc_channel(0);
   while(read_adc()) {
	val=read_adc();
	t=round(val*0.48876);                   //as per http://www.best-microcontroller-projects.com/temperature-recorder.html tutorial
	delay_ms(500);
	printf("T%d",t);				//Output temperature
My code looks ok and when trying to compile, I get this error:
Clean: Deleting intermediary and output files.
Clean: Deleted file "final.ESYM".
Clean Warning: File "C:\Program Files\PICC\final.o" doesn't exist.
Clean: Deleted file "final.ERR".
Clean: Done.
Executing: "C:\Program files\Picc\CCSC.exe" +FM "final.c" +DF +LN +T +A +M +Z +Y=9 +EA
*** Error 12 "final.c" Line 21(10,11): Undefined identifier  -- setup_adc
*** Error 12 "final.c" Line 22(16,17): Undefined identifier  -- setup_adc_ports
*** Error 12 "final.c" Line 23(16,17): Undefined identifier  -- set_adc_channel
*** Error 12 "final.c" Line 26(8,9): Undefined identifier  -- round
      4 Errors,  0 Warnings.
Build Failed.
Halting build on first failure as requested.
BUILD FAILED: Thu Apr 26 00:11:19 2012
Note the setup errors and the round error yet math.h is included.
When I change to #include <16F877A.h>, No errors except the round error. I am not supposed to use 16F877A though. Only 16F628 is available for me. Someone kindly help.
Thanks
LM35 is a temperature sensor with analog output. You can connect it to 16F628's AN0 or AN1.
void main(){
    init();  //disable interrupts, select analog input in, set tri-status, ans so on
    while (1){
       delay1ms();
       convert(temperature);  //convert the temperature at a certain interval
What compiler and IDE did you use? HI-TECH and MPLAB? which version?
Thank you for reply. I am using CCS C compiler and I have just noticed that they don't have compiler support for 16F628 adc module. Hitech looks good too. Can you write for me a sample code in hitech that gets temperature from maybe LM35 attached to AN0 and transmit it via rs232? I am using 4mHz crystal. Kindly introduce me to it. Thanks once again.
[If we have tweek for ccs too, kindly let me know]
The 16F628 Does NOT have ADCs. AN0 and AN1 are comoparator inputs NOT ADCs. Read the datasheet. In the Table of Contents on page 3 there is no mention of Analog to Digital converters. On page 8 it does not show ADCs. There is no compiler that can change the fact.
