how to read file format in PostScript
nooknikz said:
ex. gcc.ps.gz
thank you
$gzip -d gcc.ps.gz
$ggv gcc.ps
also you may want to check the file type with the file command
you must use the Acrobat Distiller to export your .ps file to .pdf file. After that, you read .pdf file by Acrobat reader, or acrobat adobe
when you installing the adobe acrobat, you must check to install the Acrobat Distiller
get Ghostscript 7.04
it would be nice to specify Operating System before asking such questions :(
I agree with a person above, Its better if you specify type of OS,
Linux
Uncompress it and just run GSview,
Windows,
Use GSView, but take care while installing Acrobat Reader
install adobe arcorbat ....
it can transfer ps to pdf......
and you can read by arcorbat reader
on linux, you should only do:
1) gzip -d gcc.ps.gz
2) gv gcc.ps
(hope you selected gv when you were installing your linux:)
Hello,
you must install the Adobe acrobat full version. the adobe reader itself can not open the postscript files.
mems123
Like sss say: use GSView, but to use it you should either get GhostScript.
HH
NeuralC
