How to read data from soundcard IO ?
buark
Junior Member level 1
Hy
Shortly I want to read data from my soundcard mic input (WinXP), how can I implement this. Which dll file should I use and how can I find out which IO address should I use.
thanx
Re: Soundcard IO address
In winXP, you can't just poke around directly to the IO port. You have to communicate with the driver of the corresponding hardware.
Anyway, since you are working with multimedia device (soundcard), the interface provided by DirectX API might be better suited for you.
