How to put antenna file as port 1 in ADS ?
abdoeng
Advanced Member level 2
ads help pls
hi all,i want to put antenna file as port 1,how.pls in steps
i have s par in touchstone file,is that in picture rigth,or i put port
Re: ads help pls
Hi abdoeng
Just put the S-par file in your @DS project directory
then in the schematic window use that drop down menu
to select "Data Items" The just pick the corresponding
port model of you S-Par file and link that file to the Data Item.
It should be straightforward.
Good Luck
Re: ads help pls
Please find attached an example in ADS to show this. Just change the extension in zap and unarchive directly with ADS (or use winzip).
I hope it can help.
Mazz
Re: @DS help pls
Mazz said:
Please find attached an example in @DS to show this. Just change the extension in zap and unarchive directly with @DS (or use winzip).
I hope it can help.
Mazz
who has that file in ads2003a ,i can't open it in that new version that written by it
regards
Re: ads help pls
hi all,here error picture , after i simulte,the s par at data
windows appear constant at all band ,how ?
see the touchstone file ,is that rigth format
regards
Re: ads help pls
It seems like you are sweeping this device out side of it's Frequency range.
The S-Para is only defind from 8GHz-12GHz so make sure your FREQ SWEEP
is with in this range.
Cheers
Re: ads help pls
Hi guys,
I'm doing a similar simulation: plugging S-para of antenna from Momentum sim into HB sim in schematic. However, after I do this, I can't get the circuit to oscillate no matter what... The S11 data is from 1-15GHz, oscillator freq=6GHz. Something I missed out?
Thanks!
Re: @DS help pls
Cheers
hi,are u sure that s parameter format rigth,i use the range from 8 to 12.there is error in data access item,what is it?
regards
