The schematic doesn't even put the PMOS symbols correctly in place
dead-time generation and non-optimal gate voltage range
Yes.Is it right?
The original schematic is completely wrong and your correction makes it blow up.
Just now I notice that the upper and lower original H-bridges are different. I showed only the upper one.The gate signal connection in the leftmost circuit is not identical with the original circuit. Why did you flip the inputs along with correcting the PMOS terminals?
