How to program (Bootloader) a flash(boot) memory through JTAG?
vishwa
Banned
Full Member level 2
India
Hi
How to program (Bootloader) a flash(boot) memory through JTAG and/or using microcontroller.
Any help will be appreciable.
Regards,
Vishwa
Re: JTAG Flashing
Hiya,
Usually memories are non-Jtag devices....
U need a BSDL file of microcontroller (a JTAG device) and flash.
after that u need a JTAG EDA tools...XTAG,Green hills or any other JTAG tools..
in that u need to define a link of the JTAG device to flash..
different tools support different laguage..
after that u need to load the signals(pins) of microcontroller with ur programming file..like stapl /pof..
then thru JTAG u will run the write cycle on the flash...
example..
/CS=0,/WR=0,ADDRESS=xxxx,DATA= UR FILE..
THEN JUST DO REQUIRED ACTION DEPENDS UPON THE FLASH..WRITE PROTECT, OR SETTING THE DONE BIT..
ITS IS EASY...JOB..ITS CALLED AS ISP (in system programming)
any more doubts??
tom...
JTAG Flashing
i think these j-tag modes enable just the programming of parallel flash memories. Some DSPs cans bootload fom spi-memories. If you want to bootload from an Spi device, i don't think, that you can to program via j-tag.
So that types, you can program via simple spi programmers, like ponyprog. I hope, but i'm not shure. knows anybody anything about that?
