How to produce short pulses (comb generator) ?
Eugen_E
Full Member level 6
Romania
comb generator
Hello,
I need to make a comb generator (discrete) to produce marker frequencies with 10MHz spacing, with almost constant level to at least 1GHz.
I will use a 10MHz crystall oscillator and a pulse generator, with t<1 ns.
What circuits can be used for this - that don't include step recovery diodes and exotic parts.
A nonlinear amplifier/multiplier using transistors with transition frequency > 6 GHz would be better?
Thanks
comb generator >1 ghz circuit
Thanks for the reply.
I need this for a comb generator, to generate marker frequencies, not for testing diodes. So the pulse amplitude doesn't have to be high, but the pulse width should be < 1ns, thus the rise/fall times should be, the lowest possible.
So I need something that feed with 10MHz will generate quite constant armonics (the levels for odd or even should be near) to at least 1GHz.
I mean something like in this style, maybe with a few design considerations/equations:
http://www.vk2zay.net/article.php/41
The simple harmonic generators will never give you equal spectral lines if you ask me. The variation in the amplitudes is more than 10dBs. What would help you is a high-speed PRBS generator with at least 2.5Gbps bit rate, 5Gbps recommended. The PRBS spectrum consists of discrete lines with more or less sin(x)/x envelope. You must calculate the PRBS polynomial order and clock frequency for the exact 10MHz spacing. It is no easy task to build a PRBS generator yourself, look at existing solutions.
    Eugen_E
Thanks. I won't go so complex, because is not a professional application... wanted to know the best option with common parts.
The BAT41 Schottky diode can be used at frequencies in the range of hundreds MHz?
