How to produce a fixed output of 12V from a 15V input ?
sotong
Newbie level 3
Newbie level 3
DC-DC Converter
How can I produce a fixed output of 12V from a 15V input using Switch mode?
I need around 300 to 600 Watt at the output.
Any diagrams would be appreciated!
Re: DC-DC Converter
Here is a power supply that can be used for 12V output voltage with a wide range of input voltages.
For currents of this magnitude you will have to add some MOSFETs in parallel to the power MOSFET ..
