How exact do you need it?
You can take a quartz oscillator i.e. from Seiko, you can build an r-c multivibrator with 2 transistors (ev. an Op Amp) or take a simple 555 timer , used as astable multivibrator...
K.
Surprisingly, up to now nothing was mentioned concerning the required signal shape.
Since you are using the term "frequency" which normally is reserved for sinusoidal signals only, here is my question:
What signal shape do you need? Squarewave (with a specific repetition rate) or sinus (with a specific frequency)?
hi i'm interest too with that generator.. if you don`t mind, can you share with me how to create it? because my final project is create the 100 khz Loran -c generator..
