How to Plug and Play COM port?
elchula
Member level 3
Member level 3
io_ch26.pdf
I want to build a circuit, this circuit interfaces to Windows by COM port. And when I Plug the cable of this circuit to COM port ---> Windows will dectect automatically this circuit (or this device)....
How to build this circuit, and intefacing circuit 's controlled by whichever standard?
Help me. Thanx!
Hello,
I don't think that's possible.
Windows can do "plug+Play" hardware detection on the serial port, but I'm not sure if a restart is needed. See here:
However, if that is not really what you need...
You can make your *application* running on the PC recognize the fact that something has been sent to the serial port, but not just the connection of a device if it does not send anything.
For instance, you can use the serial port interrupt to trigger your application on a received character, a change in "Carrier Detect" or change in "Request To Send" signals.
If this method is useful to you, see here for a little more detail:
Cheers,
FoxyRick.
