I wanted to plot the Gain of the microstrip antenna which i have created in ADS Layout, I want Gain V/s Frequency plot, Can you please let me know how can i get it . becuase i only see GAIN in the schematic window and not in layout.?
I don't know of any way to generate a plot like that with ADS Momentum. I know other apps like CST have features like that, but have only seen them in presentation, not actually done them personally. You could always go about it the long way (generate the antenna gain plot at one frequency, identify the peak value, record on paper, repeat, then plot values in Excel, etc).
Also, I want to see the 2 dimensional View of the radiation pattern in ADS , I can see the 3 Dimensional but not 2 dimensional. When i select 2 dimensional, i get Linear,Circular,Absolute,Power POLARIZATION , but not the 2D Radiattion pattern.
I'm not familiar with that dialog box, but it sounds like it's asking you for which type of plot you want, specifically:
Linear - Gain assuming linear polarization
Circular- Gain assuming circular polarization
Absolute - Absolute magnitude of gain
Power - Power gain
POLARIZATION - plot of polarization trend (vertical, horizontal, elliptical, circular, etc).
My suggestion, use the ADS help menu and see what it tells you about those plot types. ADS's help is quite full of good information.
I'd wager that Absolute or Power will give you want you want, assuming you pick the right 2D "slice" to look at. I'd plot your 3D radiation pattern, note a few key points (peak gain on main lobe, approximate gain of side lobes, etc). Then, run your 2D plot and find the one that matches those values. Then you should have correlation between the 3D gain plot and your selected 2D plot.
