How to plot the maximum of some sine waves versus the corresponding parameter value?
ravet
Member level 5
Member level 5
DSO
hello
i made transit analysis in cadence, and make parametric sweep, the result is several sine waves versus time , each corresponds to a parameter value that i made sweep for it,,,,now , i want to plot the maximum of those sine waves versus the corresponding parameter value,, can i make that using the calculator or anything else? if yes, how???
thanks
cadence calculater
Yes. You can use the calculator to build a expression and plot it. You can also enter the expression in "Output / Setup ..." form of ADE. If the net name you want to view is "/OUT", then the expression is:
ymax(VT("/OUT"))
This function will return a scalar value for a single simulation run. When you do a parametric sweep, expressions with scalar results will be ploted vs. the sweep parameter.
    ravet
Re: cadence calculater
use "ymax" to get the max. value corresponding to a variable
