How to plot OP parameter with sweep variable in Spectre?
peterlau1984
Junior Member level 1
spectre transconductance
Hello everyone,
I am confused how can i plot the operation point parameters with sweep variable in Spectre?
For example, how to plot transconductance of a MOSFET versus Vgs?
Thank you so much!
using sweep command for spectre
peterlau1984 said:
Hello everyone,
Thank you so much!
As i know, use the belowing:
set vgs as a variable, sweep vgs, set plot as OP("/M0","gm")
plot dc sweep parameters,spectre
Thanks for your reply.
I did the setting as you mentioned, and run the dc simulation. However, I only can get a value of gm correspond to the value of Vgs set in variable tab, instead of a waveform.
Is there any other methods?
spectre sweep parameter
You need to save the parameter of the transistor before running the sim. The operating point info is not saved by default for dc sweep. You can do that by creating a .scs file with the command
save M0:gm
and then add that file as a stimuli file in ADE or manually include that line in the input.scs file
spectre operating point at different dc sweeps
if youre using MMSIM6.2 and up, try save *:eek:ppoint to save all swept parameters
how to plot operating point information spectre
first,you should save operating points in a dc analysis,then do parameter sweep,after that,you can do as iamxo says.
operation point mosfet spectre
I did it as tanuuaner said, and it works.
but it seems to waste a sweep variable, because the dc sweep and the parametric analysis use the same seep variable.
thanks!
spectre plot parameter
Use the Parametric Analysis to get the waveform.
