[SOLVED] How to plot gain vs frequency curve in ADS for an amplifier
parthaucp
Newbie level 5
Newbie level 5
kindly tell how to plot gain vs frequency curve in ADS for an amplifier.
well you are probably doing an AC simulation ?
you can use this setup. I used ideal opamp you can replace it.
But if you are doing RF design like LNA you have to do s-parameter simulation and check you s(2,1)
If you are designing Power amplifier you have to check HB or Harmonic balance simulation which is a long story since you can do harmonic balance only for 1 frequency.
