OMID-313
Junior Member level 2
- Joined
- Dec 27, 2008
- Messages
- 24
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Solar System
- Activity points
- 1,448
Hi everybody
I have a dataset of points (XYZ as the coordinates) and V as the value at each point.
(Each of the above 4 data (X,Y,Z,V) are vectors e.g. 1x1000 vectors.)
I've plotted the 3D surface using patch command. (by the use of faces & vertices)
Now here goes the problem :
How can I plot the contour lines of V (NOT Z) over the 3D surface !?
(Actually the contour3 function plots 3D contour lines of Z ; But I need contour lines of V. )
I want some type of function or command that gets x,y,z and plots contours of V.
Actually I want something like **broken link removed** or even **broken link removed**.
Thanks a billion for your help.
