How to place transistor in layout XL (ic5141)???
Depp
Member level 3
Member level 3
how to place transistor
I executed "generate from source ",but there's no transistor in the layout, as u can see the result in attachment.
How could I place those transistors into the layout ???
I'm using the ic5141.
Thank you !!!
this is the result of what i want .
any one can help me ???
Thank you so much !!!
I can see some of your transistors, but you need first to place them then use SHIFT+F.
Sometimes Layout XL looks like lagging in such issues.
Try shut down icfb and restart. Tell me the results.
D.
    Depp
thank you dkace, shift+f did a good job.hehe
btw, shift+f means what???
do you have any tutorial for the setting of layout XL ??? i encountered some other problems when i try to route automatically.
hi
you can get the information from cadecne document
for this type cdsdoc in the terminal
regards
analayout
    Depp
shift+f allows you see all layers layout
contrl+f takes every cells and sub cells as just a box.
    Depp
I do agree that best tutorials are inside documentation of CADENCE, but even better is to focus on a design and ask all the help you can get from collegues or from EDA Board!
Keep up the good job!
D.
    Depp
i read the cdsdoc ,but it seems different from waht i see in layout XL :-(
when i choose to "export to router", a window pop up (the attachment is the snapshot ), when i click 'ok", another window pop up titled "Find Router" . does this mean i don't have the router???
or whether i made mistake some where in setting ???
Thank you.
thank you soooooooo much.
you need to install icc11241 for the router, which is not part of ic5141 package
