How to ping a node with data? (C source code)
feiutm9898
Full Member level 4
Full Member level 4
Singapore
Ping a node with data
Hello :)
I have search around google about the technique to ping a node with data. But I just get frustrated.
So, anyone can help me at here?
I need the C programming source code.
thanks ah....
regards,
Michael
from your Linux console you can use:
# ping [ -p pattern ] destination
-p pattern
You may specify up to 16 ``pad'' bytes to fill out
the packet you send. This is useful for diagnosing
data-dependent problems in a network. For example,
-p ff will cause the sent packet to be filled with
all ones.
see man pages for more info
# man ping
for sample source code you can use the source code of ping :)))
