s_cihan_tek
Full Member level 2
Soldering with Heat Gun
Hi all,
How can it be possible for IC's to be soldered using solder paste (i mean the paste which contains actual solder) and a heat gun without getting damaged? According to datasheets, most of the IC's can work under core temperatures up to 85C or even 125C for industrial grade components. But solder paste turns to actual solder at temperatures like 190C or more. How do IC's survive this temperature while getting soldered? Doesn't their core temperature rise above their maximum ratings during this period?
Regards.
Hi all,
Regards.
