[SOLVED] How to perform a Line transient in Buck converter using cadence?
AMSA84
Advanced Member level 2
Iberian Peninsula
Hi guys,
The topic says everything. I would like to perform a input voltage step to see how my converter reacts.
How can I do this? I have tried using VPWL but without success. An error occured, saying that Time is not strictly increasing. Don't know why.
Regards.
Probably an error in your VPWL source timing. If you have more than one VPWL sources, their timing must be synchronized.
Reactions: AMSA84
    AMSA84
I usually stack vdc, vpulse sources. For the PWL source, check
the t0, t1, t2... timepoints in the vpwl property list and make
sure they are (as the error message complains) monotonically
increasing.
Reactions: AMSA84
    AMSA84
