How to overwrite information inside file local system? C/C++
zenniz
Junior Member level 3
Singapore
Still a beginner here.
I have a txt file with all the value in it (Values will not exceed 10000)
//Information inside values.txt
1234
12
345
6789
How to for example overwrite the first sentence (1234) to 3210 so that the end result will be
3210
12
345
6789
Changing 1234 to 3210 is very easy, but how about changing 12 to 1235?
Before thinking about programming details, you'll need to consider file structures and what you exactly want to do.
I presume that each line is terminated with <CR><LF> without hidden spaces. Then you can easily replace a line with a different one of the same length. But to change the length, you'll need to copy and rewrite the whole file. Consider if this apprpriate or if you should use a different file structure.
It is easy
you would charge file to RAM (array, count the line of file for array size), after you change the value, you would write the file again.
int line_count(FILE *fp)
	int count=0;
	char letra;
	letra=getc(fp);
	while(!feof(fp))
		if(letra=='\n')
			count++;
		letra=getc(fp);
	rewind(fp);
	return count;
enjoy
