65656565
Newbie level 3
hi,
anyone know how to output a line/dot to a VGA monitor? i'm new to VHDL. i'm using a ALTERA UP2 board. i had found a sample program(codes are pasted below), but i'm not sure how it works, especially the check conditions for the v_count or h_count. How we know that it is 755, 659.
Eg:
--Generate Horizontal Sync Signal using H_count
IF (h_count <= 755) AND (h_count >= 659) THEN
horiz_sync <= '0';
ELSE
horiz_sync <= '1';
END IF;
Can anyone please kindly help me ? Thanks a lot !!!!!
Regards,
65656565
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_ARITH.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
ENTITY VGA_SYNC IS
PORT( clock_25Mhz, red, green, blue : IN STD_LOGIC;
red_out, green_out, blue_out, horiz_sync_out, vert_sync_out : OUT STD_LOGIC;
pixel_row, pixel_column: OUT STD_LOGIC_VECTOR(9 DOWNTO 0));
END VGA_SYNC;
ARCHITECTURE a OF VGA_SYNC IS
SIGNAL horiz_sync, vert_sync : STD_LOGIC;
SIGNAL video_on, video_on_v, video_on_h : STD_LOGIC;
SIGNAL h_count, v_count :STD_LOGIC_VECTOR(9 DOWNTO 0);
BEGIN
-- video_on is high only when RGB data is displayed
video_on <= video_on_H AND video_on_V;
PROCESS
BEGIN
WAIT UNTIL(clock_25Mhz'EVENT) AND (clock_25Mhz='1');
--Generate Horizontal and Vertical Timing Signals for Video Signal
-- H_count counts pixels (640 + extra time for sync signals)
-- Horiz_sync ------------------------------------__________--------
-- H_count 0 640 659 755 799
IF (h_count = 799) THEN
h_count <= "0000000000";
ELSE
h_count <= h_count + 1;
END IF;
horiz_sync <= '0';
ELSE
horiz_sync <= '1';
END IF;
--V_count counts rows of pixels (480 + extra time for sync signals)
-- Vert_sync -----------------------------------------------_______------------
-- V_count 0 480 493-494 524
IF (v_count >= 524) AND (h_count >= 699) THEN
v_count <= "0000000000";
ELSIF (h_count = 699) THEN
v_count <= v_count + 1;
END IF;
-- Generate Vertical Sync Signal using V_count
IF (v_count <= 494) AND (v_count >= 493) THEN
vert_sync <= '0';
ELSE
vert_sync <= '1';
END IF;
-- Generate Video on Screen Signals for Pixel Data
IF (h_count <= 639) THEN
video_on_h <= '1';
pixel_column <= h_count;
ELSE
video_on_h <= '0';
END IF;
IF (v_count <= 479) THEN
video_on_v <= '1';
pixel_row <= v_count;
ELSE
video_on_v <= '0';
END IF;
-- Put all video signals through DFFs to elminate any delays that cause a blurry image
red_out <= red AND video_on;
green_out <= green AND video_on;
blue_out <= blue AND video_on;
horiz_sync_out <= horiz_sync;
vert_sync_out <= vert_sync;
END PROCESS;
END a;
Eg:
horiz_sync <= '0';
ELSE
horiz_sync <= '1';
END IF;
Regards,
65656565
library IEEE;
ENTITY VGA_SYNC IS
END VGA_SYNC;
BEGIN
PROCESS
BEGIN
ELSE
END IF;
horiz_sync <= '0';
ELSE
horiz_sync <= '1';
END IF;
END IF;
vert_sync <= '0';
ELSE
vert_sync <= '1';
END IF;
video_on_h <= '1';
ELSE
video_on_h <= '0';
END IF;
video_on_v <= '1';
ELSE
video_on_v <= '0';
END IF;
END PROCESS;
END a;
