cmosbjt
Full Member level 5
We have a IC design team and we have a budget to buy either 2 workstations or some PCs. We will install IC EDAs such as @DS/Cadence in these machines. If we buy PC, then we install Linux and using floating license.
My question is, what should we buy, PCs or Workstation? What kind of configuration should I use?
Thanks.
Added after 5 hours 5 minutes:
We want to put all the design files in one server so that any designer in our group can access. Can PC do this job?
If we buy workstation, the drawbacks are:
1. we only have money enough for two, other than that we still need to pay the cost of Unix (2 set).
2. The CPU power seems to be not very strong when many designers use the EDA software (telnet) at the same time.
Thanks.
