How to optimize this circuit?
shaq
Full Member level 5
Full Member level 5
set_structure -timing true
Dear all,
Thanks for your help!!!!
how to optimize a circuit
you can draw a truth table and optimize
Is the logic equal after adding redudant wire?
regards
/David
Added after 15 minutes:
Ok, i found one paper may help you and us.
regards
/David
    shaq
another methode is to use DC tool. The tool can automatically optimize combinational logic with command " set_structure -boolean true".
Regards
/David
set_structure true is the default option when compiling with DC, you can set_flatten true before compling and you'll get a two-level logic in structure sum-of-product
Thanks David for posting the paper.
Does any body have some good books regarding logic optimization??
thanks
pra
Added after 24 minutes:
The logic for O2 in the above circuit will not be equal after adding the redundant wire.
I hope the inputs are to be changed....
does anybody solved this one!!! if so then plz share with us :)
thanks
pra
