player80
Full Member level 2
![Full Member level 2](/styles/images/ranks/elevel2.gif)
I'm trying to set up some goal I would like to achieve using a cypress ez-usb and FPGA
I would like to read 2 serial channels via FPGA, multiplex it and send it to the ez-usb controller.
Now I'm a software engineer, and only have a rough idea which components I would need for that.
* EZ-USB FX2 for the USB part
* FPGA / CPLD for the multiplexing part.
Since I'm a beginner I have no idea where to start with the FPGA/CPLD part how the multiplexing procedure should work.
Would this require to write the data from input 1 to some memory and once it's completed send it to the FX2?
For the serial input data I would think about 2 lines per input, clock and data (to make it easier at the beginning I'd ignore the synchronization part and just simulate 2x8bit inputs, the inputs should not be limited by 8 bits in the future I would like to be able to extend this eg. to 48 bytes / 384 bits or more per channel).
Can someone give me a hint what I would have to study or is there any example out there which I could have a look at in order to learn about what I want?
