How to modify my hostname in RH7.3 ?
elone
Member level 3
Member level 3
how to modify hostname
edit /etc/hosts
add or modified this line
xxx.xxx.xxx.xxx(ip) xxx.domain xxxx
After I modified the hostname in /etc/hosts or the Control Centre GUI, the SENDMAIL reported a failure said that 'hostname not find' when rebooting, I had to modify the hostname back to 'localhost'.
How can I do, then?
Thx a heap.
Leave localhost un-changed .
Add the hostname show in ur license file in /ect/hosts .
U can use 'hostname' in command line to modify system hostname .
I have no idea if it is related to license's 'hostname' .
the easiest way
to modify hostname by using the linuxconf...very easy
