VerLearn
Newbie level 5
How do I model smart primitives in Verilog?
Example: I should design a majority function that can take any number of inputs(finite).
I tried with FSM. The problem was: I could not call it and use it as regular primitives like AND, OR etc.
My Code: (I cannot use this code as I do with standard primitives.)
module s_majority(in,out,clk,rst);
// In - one bit input, clk - clock, rst - reset
input in,clk,rst;
// out - output
output reg out;
// Declaring local parameter for the state machine
localparam s0=0;
// Declaring state machine case variable
reg machine;
// count_zero - counts zeros. count_one - counts ones.
reg [31:0] count_zero,count_one;
always@(posedge clk) begin
if(rst) machine <= s0;
else machine <= machine;
end
always@(machine) begin
case(machine)
s0: begin
// Counting ones and zeros
if(in==1) count_one=count_one+1;
else if(in==0) count_zero=count_zero+1;
else begin
count_one=count_one;
count_zero=count_zero;
end
// Comparing counts of zeros and ones
if(count_one>=count_zero) out=1;
else out=0;
end
default: begin
count_one=0;
count_zero=0;
out = 0;
machine = s0;
end
endcase
end
endmodule
module tb();
reg in,clk,rst;
reg maj;
integer i;
wire out;
s_majority i1(in,out,clk,rst);
always #5 clk=~clk;
// Task to send inputs bitwise.
task check;
input [9:0] inp;
begin
#4 rst=1;
for(i=0;i<10;i=i+1) begin
#10 rst=0;
in=inp;
end
end
endtask
initial begin
clk=0;
$dumpfile("tb.vcd");
$dumpvars;
$monitor("majority=%b",maj);
// Task call
check(10'b0000011101);
maj=out;
#10;
$finish;
end
endmodule
