How to measure the inductance of a coil ?
judfid
Member level 3
Member level 3
how can i measure the inductance of a coil .
Re: inductance of a coil
hello judfid,
'inductance ' of a coil of...
which core? air/iron/ferrite?
what is frequency of interest ?
srizbf
29thapril2010
Re: inductance of a coil.
50hz or 60hz. thanks
Added after 3 minutes:
large iron coreb Thanks.
Preferably with a LCR meter. If you don't have it, apply a low AC voltage and measure voltage and current and calculate the
inductance. If the impedance isn't mostly reactive, you can use a series resistor and determine the complex impedance from the
three voltage measurements (can be solved geometrically).
I would put a capacitor across the inductor, add a series resistor and use a signal generator and oscilloscope to find the resonance.
Keith
judfid,
for 50/60hz iron core coil ,
use a 'digital lcr' meter set with 50/60Hz measurement frequency .
this is the easiest method.
other methods exist. but it requires measurement meters and computation .
srizbf
30thapril2010
hello,
When your iron core inductor has no air gap, inductance depends on AC current through the inductor. When inductance is critical, best is to measure it under similar conditions as when it is in the actual circuit.
when using an oscilloscope and also measure current (voltage across a small series resistor), you can also assess the losses and non-linear effects.
When measuring large inductances with reasonable current, keep in mind the EMF generated during current interruption can be large (electric shock, damage to equipment).
