cmosbjt
Full Member level 5
![Full Member level 5](/styles/images/ranks/flevel2.gif)
eb/n0
In order to measure the BER of my BPSK demodulator, I need to know what is the Eb/No of my input BPSK signal.
I use a function generator to generate the BPSK signal, which has a square waveform. Then I add white noise on top of the BPSK signal. By changing the white noise level, I can change the Carrier to Noise (C/N) ratio.
There is no band pass filter in front of the demodulator.
By definition:
Eb/No = C/N * Bw/fb (Bw is the bandwidth, fb is the bit rate)
Here are my questions:
1. The sqaure wave has a fundamental tone and many harmonics. How to determine the C/N? (using a spectrum analyzer (specifying the bandwidth) ? or a power meter (broad band) ? )
2. The BPSK signal I generate is a square wave, it has theoratically an infinate bandwidth as an ideal square wave has infinate harmonic components. So what is the bandwidth (Bw) in this case?
By definition:
