How to measure s parameters in a 4 port network in cadence
Advark
Member level 3
Member level 3
POA, Brazil-RS
3 ports s parameters balun cadence
Hi, i have a problem i don't really know how to measure s-parameters in a 4-port network. Do i use a balun to convert into a 2 port network o what should i do?.
This is the 4-port network i was reffering to.
I hope anyone can help me.
Regards
4 port s parameter network
You can do that with spectreRF. PDF somwhere there doc/spectreRF/spectreRF.pdf. At first you have to do PSS analysis and then the one everything to do with s-param (I forgot how is it called)
convert s-parameter from cadence to ads
Drive the network differentially and you ended up with 2 ports.
how to convert 2 port s-parameter to 4
But what happen with the values of s31 ... and s41 ...
Re: How to measure s parameters in a 4 port network in caden
Thanks. I use the balun to simplify from 4 ports to 2 ports
