dl09
Full Member level 4
if wrap copper wire around an electromagnet and measure the magnetic field, and know the number of turns and current input, could i calculate the relative permeability of the iron core?
sorry but no, you will be measuring in the airi am thinking i will measure the magnetic field a few millimeters from the core and then use equations B = uH and H = N^2A to calculate relative permeability of core. will that give me an accurate value of permeability?
There's of course a magnetic field outside the core, but no simple relation between field strength and permeability.
A classical physics lab experiment compares the inductance of two toroid coils of identical geometry, one has a non-magnetic, e.g. wooden and the other a laminated iron core.
