* I don`t see an opamp - it is an OTA, correct?
* More than that, it seems that you are applying POSITIVE feedback; WHY?
* The test signal must be feeded into the loop directly!
For AC analysis it is out of the picture. You should make sure that the feedback is connected in a negative feedback scheme.
