How to measure NF of LA? Need Help again.
rats
Newbie level 5
Newbie level 5
Denmark
I design limiting Amp, just at simulaton level. It is 10Gb/s LA. gain is 47dB.
1.I have not design input buffer and output buffer. using ST 0.13 process
2.How can I measure the NF in cadence?
3Is there any NF difference between the LA core only and with inan dout put buffer? I need help.
As I knew , I shall remove input source, put a port intead. Then in pssI shall choose beating Freq, shall 5GHz? About freq sweep range, what I shall choose? About sweep type? I also don't know what I shall do. Please help me
I do not know for cadence but is this an RF question based on your figures posted in analog forum.
I know you want a limiting amp but this is treated under the Low Noise Amplifier Dersign section of any RF book.
See if any book in RF covers cadence and I think cadence must have some documents for this purpose. If you change your mind to do things in ADS or Ansoft Designer I will be gladly to help.
What I did is not LNA, this LA NF shall be higher than 16dB, it is for optical application, actually the NF is not so important for LA, of course I still want to know how noisey it is . because TIA decide most of NF for optical reciver block, but I don't know does input matching and output buffer influence the NF.
check help document from Cadence (in the chapter or SpectreRF), you will find the LNA simulation example.
Good Luck!
