How to measure low & high current
ahmed osama
Full Member level 6
Full Member level 6
Cairo, Egypt, Egypt
dear all
how to measure the a low current about 50mA to high current about 50A , is it current transformer or shunt resistor , i found the shunt resistor expansive and using CT always use for better for high current
thanks bye
hi
i think you can use
hall effect current sensor
---------- Post added at 17:23 ---------- Previous post was at 17:04 ----------
hi
i think you can use
Now-a-days in the market very nice and of good quality Clamp ON meters are available even for DC measurement with adjustable ranges from Low to High. The easiest and trouble free way of measuring current. The shunt resistor is better but needs extensive efforts and time consuming along with a High Cost process.
please tell me what is shunt resistor method....and how it is measured
---------- Post added at 22:10 ---------- Previous post was at 22:09 ----------
Is hall effect is based on magnetic flux for measurement of current ....:???:
Here is the procedure of measuring the current with shunt resistors.
Yes Hall Effect is based on Magnetic Flux measurement system.
