sunking said:sweep the common mode voltage, make sure all the tr. not in triode, then you can get the icmr.
manissri said:The other method of calculatin the icmr is
just make the opamp in unity gain configuration sweep the + input of opamp to the supply range and check the output .the part of output is linear will be ur icmr.
u can concern the book of allan holberg for this
regds
manish
shaq said:manissri said:The other method of calculatin the icmr is
regds
manish
Hey! manissri
Do you mean that structure?
Just sweep vin then measure vout, right?
