How to measure GFSK modulation RF?
TerryADS
Full Member level 2
Full Member level 2
USA
gfsk modulation
Hi friends,
I am designing DECT that uses GFSK modulation.I am a newbie, Now I have CMD60, RF spectrum analyzer and VNA. Anyone can tell me how to measure IM2, IM3 product and supply me the test graph?
Another question, any other measurements I need to do about RF except Power, sensitivity, deviation, jitter, frequency offset and frequency drift?
Thanks
gfsk ber modulation
For intermodulation test you need another two signal generators (one modulated, and one unmodulated), and a three-way power combiner.
https://www.minicircuits.com/pdfs/ZA3PD-2.pdf
Connect CMD60 and the other two generators to the ports 1, 2, 3, and the DUT at port S. Calibrate the setup for the losses, run a loopback test at reference sensitivity with CMD60, and follow the Intermodulation spec (DECT ETSI) for the rest of the test.
More RF tests are: receiver blocking, receiver spurious emissions, receiver interference, transmitter unwanted RF power radiation, etc. Just check the ETSI DECT specification.
    TerryADS
dect reference sensitivity modulationsverfahren
Thanks,vfone.I check it,but it is not in detail.It introduce simplely that receiver intermodulation,and i do not know which IM product i can get as following photo,can you help me?
Thanks
gfsk rf
Terry
ETSI cannot specify intermodulation products as they depends from your implementation. The system is interested in overall performance degradation, so BER.
If you want to measure internal system parameters (gain, noise, linearity) you should have a system partitioning study or specification that gives you the expected values so you can measure it.
It sound strange that you are designing something but you have measurement issues. Could you please explain more in detail it to better understand?
I hope it can help.
Mazz
    TerryADS
gfsk chip
You are not looking to the right spec.
The attached one probably is not the latest but it gives good explanation how to run this RF test (and others). Go to page 69.
    TerryADS
gfsk demodulation spectrum analyzer
Mazz said:
Terry
Can you explain in detail?
Thank Mazz firstly.Because we want to evaluate the demo board,It is my first time design digital RF,i think it is different with FM system,and i need more informations about digital RF measurement firstly.especially IM product,linearity.
.in band and out band block.
I hope it can help.
Always thanks for your kindness
Mazz
Added after 24 minutes:
Also thanks vfone's kindness to me.
rf parameters for dect
Terry
Regarding the requested details, I will try to explain better with an example. Consider two differenr implementation of the DECT reveiver, the first one a superhet the second one a low IF.
In the first implementation you will have a first intermediate IF of about 110MHz and a SAW filter. In the second implementation you will have an IF of 1 MHz. For ETSI this is transparent.
Most probably you will have different gain in the two RX chains, different IM products and so on, but ETSI cannot take care about that.
It takes care of measurable end to end parameters do BER FER in RX.
Designing an RF system is the task to find the specification (such as gain, noise, Linearity...) of subblocks (from LNA, Mixer, Filter, VGA, demodulator and so on) in order to be compliant with ETSI end to end.
I hope it can help
Mazz
Reactions: funfun
    TerryADS
    funfun
strange rf spectrum
Thanks Mazz.Your explaination it is helpful,and i get it now.Attached the RF block we use,can you give me some suggestions what i can measure during estimating the RF chip?
Thanks
rf parameters you have measured
In this integrated solution, you have access only to antenna connector & TRDATA pin, so you can only measure end to end parameters, as specified in ETSI, to check if it is ETSI compliant.
Can you share with me the RF IC full datasheet?
Mazz
    TerryADS
